Boosting Waystone Drop Rates for a Higher Chance of Obtaining Faded Crisis Fragments
## 1. Upgrade and Use High-Tier Waystones with Many Modifiers
* Waystones have a **Waystone Drop Chance** stat that can range up to 700% or more.
* Use **Rare Waystones** with multiple (up to 6) suffix modifiers to maximize drop chance.
* You can craft these by corrupting Waystones with **Vaal Orbs** or using the Reforging Bench to upgrade tiers.
* More negative modifiers on Waystones and maps actually increase Waystone drop chance, so don’t shy away from “bad” mods.
## 2. Invest in Atlas Passive Tree Nodes
* Allocate points to nodes that increase:
* **Waystone Drop Chance**
* **Waystone Modifier Effect** (boosts the strength of Waystone mods)
* **Waystone Quantity** (increases the number of Waystones dropped)
* Key nodes include **Constant Crossroads**, **Teeming Horde**, **Precursor Influence**, and **Bountiful Bloodlines**.
* These nodes multiply the base drop chance and quantity, significantly improving fragment farming efficiency, including increasing the chance of obtaining the Faded Crisis Fragment.
## 3. Use Map and Waystone Modifiers
* Run **higher-tier maps** (Tier 10 and above) with multiple negative modifiers (e.g., “Monsters are Evasive,” “Increased Pack Size,” “More Magic/Rare Monsters”).
* These modifiers increase map difficulty and loot quantity, which in turn boosts Waystone drop chance.
* Apply currency like **Alchemy Orbs**, **Regal Orbs**, and **Vaal Orbs** to upgrade map tiers and add modifiers.
* Use **Precursor Tablets** in Atlas towers to increase Waystone quantity on maps.
## 4. Increase Monster Density and Kill Efficiency
* More monsters killed equals more chances for Waystones to drop.
* Use skills and gear that increase pack size and kill speed to maximize kills per map.
* Consider investing in Atlas nodes that increase monster rarity and quantity, such as **Deadly Evolution** and **Rising Danger**.
## 5. Maintain Rarity on Gear
* Item rarity on your character’s gear increases the chance for rare drops, including Waystones.
* Although it may require sacrificing some survivability, investing in rarity gear helps improve overall drop rates.
## 6. Purchase Waystones from Doryani if Needed
* If you run out of Waystones, you can buy them from Doryani’s vendor in the Ziggurat Refuge using gold.
* This ensures you can continue farming Citadels and fragments without interruption.
* Use rare, highly modified Waystones and high-tier maps with negative mods to maximize drop chance.
* Invest Atlas passive points in Waystone drop and quantity nodes.
* Increase monster density and kill speed for more drops.
* Maintain rarity on your gear to boost drop rates.
* Supplement your supply by purchasing Waystones if necessary.
