eld.gg MLB The Show 25 Stubs: Elite squad
Kongyawen
Kayıt: 09 Ağu 2025, 05:08
Otomobil: Terrano
Mesajgönderen Kongyawen » 09 Ağu 2025, 05:53
Best Strategies for GOAT Runs
1. Build a Balanced Squad
Avoid stacking only power hitters. You need contact, speed, and MLB The Show 25 Stubs defense.
Prioritize players with high clutch and vision stats. These matter most against top-tier AI pitchers.
Defensive mistakes are punished in GOAT mode. Use fielders with 80+ fielding and strong arms.
Pitching Tips
Use off-speed pitches low and away to keep AI batters guessing.
Avoid predictable patterns. AI on GOAT will recognize and adjust quickly.
Prioritize pitchers with high control, stamina, and clutch stats.
Use your bullpen intelligently – don’t let starters go too deep.
Batting Approach
Sit on fastballs and adjust to off-speed.
Use Zone Hitting for better control of PCI placement.
Don’t swing early in the count unless it’s a hanger. The AI throws more junk in GOAT.
Plate discipline wins games: walk totals matter and get you XP bonuses too.
Smart Base Running
Avoid unnecessary steals unless you have elite speed and the pitcher is slow to the plate.
Use hit-and-run tactics occasionally to throw off the AI’s defensive timing.
Always take the extra base on outfielders with weak arms – use the in-game scouting info.
Suggested Loadout
If using a Ballplayer, equip them with:
Perks focused on Contact and Vision
Diamond-tier gear (Bat, Gloves, Cleats) with stat boosts to Power and Speed
Choose SS or CF archetypes for maximum defensive utility
Mindset and Run Management
If you lose a game early in the run, consider retreating and starting over to preserve resources.
Treat each game like a playoff match: no mercy, no mistakes.
Play at a time of day when you're most focused – fatigue will lead to poor PCI placement and errors.
Final Thoughts
Diamond Quest on GOAT difficulty is where the best players prove themselves. It’s not just about skill – it’s about discipline, team composition, and MLB The Show 25 Stubs for sale smart decision-making. If you can conquer GOAT runs consistently, you’ll not only build an elite squad, but also earn enough Stubs to avoid ever spending real money.
